We developed an application using the version 3 API and used SimpleMarkerSymbols with an SVG path to produce the expected symbol. However, using a similar input for version 4 API, the result does not show properly and I'm wondering if this is just a bug. I created a simple test case of a svg path for a circle with an X inside. The image on the left shows the version 4 API compared to the version 3 API on the right side.
Version 4 API seems to pixelize the symbol and does not show the second path for the X at all.
I also created two example CodePens that show the differences.
https://codepen.io/j_rsg/pen/GRWLpmJ
https://codepen.io/j_rsg/pen/XWMQmMY
Has anyone experienced similar issues when converting their version 3 svg symbols to version 4 or can comment if this is a known issue? Thanks.
