AMD confusion about parser.parse
5837
10
05-22-2015 09:43 AM
SteveCole
Honored Contributor
I'm jumping off the deep end and starting to convert some apps to AMD style that were originally written in legacy dojo. One thing I've picked up about migrating to AMD is that the legacy practice of doing this:
<script type ="text/javascript">
var dojoConfig = {parseOnLoad: true};
</script>
in the HTML header section has been replaced by doing this:
ready(function() {
     parser.parse();
down in the Javascript code. I never questioned this; I just did it. In my current work trying to migrate a legacy app to AMD, I ran into a maddening issue where my attempts to establish a listener event on a dojo form that had two radio checkboxes as choices:
// Event listener to enable/disable controls based on the input method chosen
dijit.byId("frmEndMethod").on('change', function() {
would always error out because dijit.byId() couldn't find the widget and thus, returned undefined. The code was within the ready(function() {...}); so it should have no problems finding it. In fact, I could type "dijit.byId("frmEndMethod")" into the console after page load and it does return the dijit. No matter what I tried, I could not get this to work. Then I reverted back the the legacy variable declaration in the header and commented out parser.parse() in my JS code.
Surprise, surprise- it loaded without error and the event now triggers. So what gives? Am I "wrong" to still use the dojoConfig variable with AMD style coding? I mean, it seems to work, which is the whole point but is there something I'm missing?
Steve
SteveCole
Honored Contributor
I believe I did try it but I think it didn't make a difference. I had the sense that the code for dijit.byId was getting called before it was "ready" but I couldn't prevent it unless I went the parseOnLoad route.
Thejus' suggestion of moving the parse.parse outside of the ready() function makes some sense but I haven't had the time yet to try it. My main intent from my original post was to ask if the technique of using parseOnLoad has fallen out of favor (or is no longer needed) when using AMD style coding.
