After loading webmap, set the map's showLabels property to true
3171
04-13-2016 08:29 AM
MarcBate
After loading webmap, set arcgisUtils.createMap I want to be able to add new layers which I label.  However, There's no map.setShowLabels method, and setting the map.showLabels = true directly doesn't work (where map is from the response.map) .
Am I missing something because surely I should be able to label my layers after loading a webmap?
Tags (3)
MarcBate
I found the answer to this myself.  The arcgisUtils.createMap takes a mapoptions parameter:
var deferred = arcgisUtils.createMap(id, "map", {
  mapOptions: {
  showLabels : true
