After every 5 seconds performing apply edits for multiple layers and if application is idle for an hour then the map freeze for some seconds
1674
09-02-2020 10:04 PM
ShefaliMantri
I create multiple feature layers from external service(JSON data). After every 5 seconds apply edit is performed on each layer (min 200 records per layer for apply edit). Now the application is idle for an hour and after that if I zoom or pan the map or an open popup every operation is taking more time so it looks like the map is freeze for some seconds.
Issues: After an hour when the application idle map operation is not smooth.
Question: Why map is freezing or taking much time to perform any operation when the application is idle for an hour or more?
VictorTey
shefali Mantri can think of a couple of areas to check
cache expiring
browser memory (are you leaking memory in your code)
token expiry?
ShefaliMantri
cache is disabled.
Yes, some memory leak is there. I checked from the chrome browser task manager. so any suggestion on that
no token expiry.
