Add ShowSaveButton on Directiosn Widget arcgis api 3.38
3310
8
10-27-2021 04:38 AM
benchikh
Im working with Directions Widget with arcgis JS version 3.38 and want to display the Save button on the widget, so I have added the ShowSabeButton parameter. But still can't displayed on the widget!
 var directionsW = new Directions({
            map: map,
            routeTaskUrl:
             "https://192.168.7.45:6443/arcgis/rest/services/CALCUL_ITINERAIRE/NAServer/Route",
            **showSaveButton: true**
Can anyone help me with this please?
AndyWhitaker1
Not sure if this helps, but the save button sounds like it will be shown if your network service is on ArcGIS Online or Portal.
https://developers.arcgis.com/javascript/3/jsapi/directions-amd.html#showsavebutton
"Applicable if the widget works with a Network Analyst Server federated with ArcGIS Online or Portal. In addition, the widget may display this button in instances where it's needed to save and share routes with Navigator or other client applications. (Added at v3.17)"
You could always create your own save button in JavaScript that mimics the default ArcGIS one by applying the same CSS.  Something like this:
const savePrintButtonContainer = this.map.directions._savePrintBtnContainer;
const savebtn = domConstruct.toDom(
							"<div tabIndex='0' role='button' class='esriResultsSave esriDirectionsButton esriDirectionsTabButton' data-blur-on-click='true' data-dojo-attach-point='saveBtn' title='Save Route' id='saveButton' style='display: none;'> \
						</div>");
this._saveButton = domConstruct.place(savebtn, savePrintButtonContainer, "last");
$(this._saveButton).on("click", this.saveRoute.bind(this));
benchikh
Many thanks for your reply, I will try doing your suggestions and let you know !
benchikh
Thanks again for your help, I have tried your code above, but got the following error "domConstruct.toDom is not a function"
below is my declaration, Im a beginner so your help would be much appreciated
require([ "esri/map", "esri/dijit/Directions", "dojo/parser", "esri/tasks/locator", "esri/tasks/FeatureSet", "esri/tasks/DirectionsFeatureSet", "dijit/layout/BorderContainer", "dijit/layout/ContentPane", "dojo/dom-construct", "dojo/dom", "dojo/on", "dojo/domReady!" ], function ( Map, Directions, parser, Locator, FeatureSet, DirectionsFeatureSet, domConstruct, dom, on
KenBuja
MVP Esteemed Contributor
The function arguments have to be in the same order as the require modules:
require([ "esri/map", "esri/dijit/Directions", "dojo/parser", "esri/tasks/locator", "esri/tasks/FeatureSet", "esri/tasks/DirectionsFeatureSet", "dojo/dom-construct", "dojo/dom", "dojo/on", "dijit/layout/BorderContainer", "dijit/layout/ContentPane", "dojo/domReady!" ],
benchikh
Many thanks looks like the error message now is changed to  "_savePrintBtnContainer" is not recognized in the below instruction : (knowing that I have a div with "_savePrintBtnContainer" class name)
ERROR : Cannot read properties of undefined (reading '_savePrintBtnContainer')
KenBuja
This code works in the sample. It gets the container directly from the widget, but has to wait until the widget is loaded
directions.on("load", function(){
  const savePrintButtonContainer = directions._savePrintBtnContainer;
  console.log(savePrintButtonContainer);
Noah-Sager
Another option is to try your route service in the sample below to make sure it works (uncomment line 51).
https://developers.arcgis.com/javascript/3/sandbox/sandbox.html?sample=widget_directions_basic
benchikh
Yes, My route service works fine, except that I cannot see the savebtn .
