As always, thanks for ur help Robert, now i can understand that js is a very sensitive language to learn!.
I have another question related with Dynamic Layers.
Is there a way to get the data in a popupwindow from a dynamic layer to be shown?
I have a service that the only way to be shown propertly is adding a Dynamic Layer, but the thing i want to do is, when the user clic one feature, it displays a popup with the info about that feature that he was clicking.
I can do it through a feature service easily, but when i try to put the dynamic layer and the feature layers using the "map.addLayers(dynamicLayer,featureLayer1,featureLayer2,...etc)" i cannot see the information about. (Seems like it is overwritten for the dynamic layer as a image).
The code is the same that i showed in the beginning, but i want to add a Dynamic Layer + FeatureLayers.
Like:
var map;
var identityManagerOK ="NO";
//Establece todo lo requerido para funcionar. "LIBRERIAS"
require([
"dojo/_base/array",
"dojo/parser",
"esri/config",
"esri/dijit/editing/Editor",
"esri/dijit/editing/TemplatePicker",
"esri/layers/FeatureLayer",
"esri/layers/ArcGISDynamicMapServiceLayer",
"esri/layers/ImageParameters",
"esri/map",
"esri/IdentityManager",
"dijit/layout/ContentPane",
"dijit/layout/BorderContainer",
"dojo/domReady!"],
function (arrayUtils, parser, esriConfig, Editor, TemplatePicker, FeatureLayer, ArcGISDynamicMapServiceLayer, ImageParameters, Map, IdentityManager){
parser.parse();
esriConfig.defaults.io.proxyUrl = "/proxy/";
//GENERA UN MAPA BASE
map = new Map("map", {
basemap: "topo",
center: [-71.0659,-32.9252], // longitude, latitude
zoom: 8
//add editor when secureLayer is added.
map.on("layers-add-result", initEditing);
//add the feature layer - secure service - token is required
var secureLayer = new FeatureLayer("",
{ mode: FeatureLayer.MODE_ONDEMAND,outFields: ["nombre"] });
var imageParameters = new ImageParameters();
imageParameters.format = "jpeg"; //set the image type to PNG24, note default is PNG8.
//My dynamicLayer map server
var dynamicMapServiceLayer = new ArcGISDynamicMapServiceLayer("", {
"opacity" : 0.5,
"imageParameters" : imageParameters
dynamicMapServiceLayer.setVisibleLayers([1,2,5]);
//Add layers to the map
map.addLayers([dynamicMapServiceLayer,secureLayer]);
//Genera el infowindow para mostrar datos
map.infoWindow.resize(200, 200);
function initEditing(event){
// alert("entre");
var results = event.layers;
var featureLayerInfos = arrayUtils.map(results, function (result){
return {
"featureLayer": result.layer
var layers = arrayUtils.map(results, function (result){
return result.layer;
var templatePicker = new TemplatePicker({
featureLayers: layers,
rows: 'auto',
columns: 2
}, "templatePickerDiv");
templatePicker.startup();
//setup the editor widget
var settings = {
map: map,
templatePicker: templatePicker,
layerInfos: featureLayerInfos
var params = {
settings: settings
var editorWidget = new Editor(params);
map.enableSnapping();
editorWidget.startup();
//VARIABLE PARA SABER SI EL LOGIN CORRESPONDE O NO
identityManagerOK="YES";
//alert(identityManagerOK);
identityManagerOK="NO";
// alert(identityManagerOK);
