Is anyone else having issues with zooming into an area in 4.11? I tested the exact same app in 4.10 and 4.11 and I can only zoom in to the extent below. Previous was able to zoom until a house filled most of the screen. Have tried this with a few different apps so I don't think it's a code issue. Is this a known bug? It happens when you switch to a vector basemap in the Javascript samples as well.
Solved! Go to Solution.
Hi there,
We are aware of this issue at 4.11 and will be fixed in the next release. In meantime, if you need a workaround, you can set the view.constraints' lod after the view is loaded.
view.when().then(() => { view.constraints = { ...view.constraints, lods: [] }; // specify lods });
Jeremy,
This sample works fine:
I was looking at https://developers.arcgis.com/javascript/latest/sample-code/sandbox/index.html?sample=intro-mapview and changing the basemap code to:
var map = new Map({
basemap: "gray-vector"
Jeremy,
I do see the issue with gray-vector. if you use topo-vector it is not an issue though. This is something you need to call tech support about and log a bug.
Hi there,
