What's the default mouse pointer for a map?
670
11-29-2012 04:36 PM
stevemclaughlin
I get the 'hand' tool for a mouse pointer, where a click and drag moves the map.
In the ArcGIS Resources Samples, the default mouse pointer is the pointer, not the 'hand' tool.
For example if you run this on the web:
(InfoWindow on Click)  - it takes a while to load.
http://resources.arcgis.com/en/help/flex-api/samples/#/InfoWindow_on_Click/01nq00000031000000/
The mouse pointer is the pointer,
When I copy the code and run it on my windows machine, the mouse pointer is the hand. (ie. the grab and move tool)
Is there a way to default it to a pointer?
I'm using: ArcGIS API for Flex version 2.4.
Build date 2011-07-25.
RobertScheitlin__GISP
Steve,
   See the Map components documentation and look for the openHandCursorVisible property.
http://resources.arcgis.com/en/help/flex-api/apiref/com/esri/ags/Map.html
Don't forget to click the Mark as answer check on this post and to click the top arrow (promote).
Follow these steps as shown in the below graphic:
