Weird query done by DetailsTask
1244
09-01-2010 08:24 AM
Ganael_Jatteau
Hello,
I use a DetailsTask to explore a rest layer on a arcgis 10 workgroup. Sometimes, the http request done by this task looks like:
http://localhost:8080/query?outFields=&f=json&returnGeometry=false&where=null%20is%20not%20null&spatialRel=esriSpatialRelIntersects"]. URL: http://localhost:8080/query?outFields=&f=json&returnGeometry=false&where=null%20is%20not%20null&spatialRel=esriSpatialRelIntersects
And of course it returns an error.
The code is quite simple:
var detailsTask:DetailsTask = new DetailsTask();
detailsTask.url = "http://ags10wg:8399/arcgis/rest/services/test1/MapServer";
detailsTask.getDetails(7, new AsyncResponder(detailResult, onFault));
Anybody else got this problem?
Ganael_Jatteau
It seems that this problem happens when the layer names have some aliases. I've downloaded the latest flex lib 2.0 from the resource center and the problem still happens.
the method:
detailsTask.getDetails(layerId, new AsyncResponder(detailResult, onFault));
first queries the JSON of the layer. Then there must be a bug interpreting the json because the next query done to the server is the one described in the previous post.
Ganael_Jatteau
I confirm. DetailsTask doesn't work when the layer names are different from the datasources in a service.
DasaPaddock
Can you share the code in your detailResult function?
DasaPaddock
I'm not able to reproduce this issue using the code below. Can you modify the code below to show how this issue can be reproduced?
<?xml version="1.0" encoding="utf-8"?>
<s:Application xmlns:fx="http://ns.adobe.com/mxml/2009"
               xmlns:s="library://ns.adobe.com/flex/spark"
               xmlns:esri="http://www.esri.com/2008/ags">
    <s:layout>
        <s:VerticalLayout horizontalAlign="center" paddingTop="10"/>
    </s:layout>
    <fx:Script>
        <![CDATA[
            import mx.rpc.AsyncResponder;
            protected function button1_clickHandler(event:MouseEvent):void
                detailsTask.getDetails(0, new AsyncResponder(myResultFunction, myFaultFunction));
                function myResultFunction(result:Object, token:Object = null):void
                    trace(result);
                function myFaultFunction(error:Object, token:Object = null):void
                    trace(error);
    </fx:Script>
    <fx:Declarations>
        <esri:DetailsTask id="detailsTask" url="http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/SanFrancisco/311Incidents/MapServer"/>
    </fx:Declarations>
    <s:Button click="button1_clickHandler(event)" label="Get Details"/>
</s:Application>
