using SSL in the script
1134
04-02-2013 06:05 PM
SherryHuang
Hi all,
I am using the arcgis server 10.1 SP1.
I need to use the SSL for my rest/manager site.
But it couldn't just like change the url in my script.
My basemap wouldn't show.
Does the script differ between the http and https?
Cuz I couldn't find the related resource about this.
Anyone fights with the SSL as well before that can get me through this.
Thank you.
Sincerely,
Sherry
EokNgo
If by basemap you are referring to your own map service, you'll need to provide a token in order for it to appear.
Here's some documentation on how to acquire a token for use.
http://resources.arcgis.com/en/help/main/10.1/index.html#/Acquiring_ArcGIS_tokens/0154000005rp000000...
If you're referring to tiled map service like Bing Maps or ArcGIS Online, this could be another reason.
You may want to use a tool like Fiddler or HTTPFox to determine what the response/error is.
Hope this helps you get started.
SherryHuang
Thank you for your reply.
I think I don't need to have a token to show the map before I make the service into private service.
I leave my service to be public to avoid the token.
Best,
Sherry
