Using a layer with polygon in a livelayer widget
1705
08-09-2010 06:37 AM
ldv78ldv78
I,
I started to use flexviewer so i can't change lot of thinks but, i want to use the livelayer widget to display another geometry type ==> a polygon.
Is't possible to do that. In fact i know it does't work like that 🙂
I see a function name getpoint for a polygon object , how use it ?
How display my polygon layer ... in advance thanks for your help
ldv78ldv78
No ideas ??
RobertScheitlin__GISP
ldv78,
    I don't think that your question is very clear. The LiveLayerWidget can easily display a point or polygon mapservice layer all you do is specify a xml file for that specific layer. Is your question how to configure the widget?
ldv78ldv78
I,
Thanks for your help.
I try to configure the livelayer widget with a point mapservice no problem it works.
But I change to a polygon layer it doesn't work.
I got an error "could not decode"
MLowry
I,
Post up your livelayer widget mxml and xml so we can help out.
ldv78ldv78
ouch my livelayer xml et mxml must correspond ???
that's why it doesn't work i must to modify my mxml file.
Thanks.
