use url to jump to an exten in 1.3 viewer?
1053
04-26-2011 12:17 AM
DanielLewis
Is it possible (or can a modification be made) to have the 1.3 viewer jump/display a desired extent (and also enable disable specific layers) from a given url (so a person could e-mail a link to another person)?
example:  https://webviewer.com/flex/index.html?x=1111111&y=2222222&layer1=1&layer2=0
Wayne
RobertScheitlin__GISP
Daniel,
   Here is a link to some info on what you are looking to do. You will have to extend any examples of what you find to met your specific needs.
http://forums.esri.com/Thread.asp?c=158&f=2421&t=266031&mc=10.
DanielLewis
Daniel,
Thank you, that's a great help.
DanielLewis
Robert,
Thanks again.
I'm now trying to create a widget that shows the URL (with extent) for the user to easily copy (into e-mail, for example).  I have the widget written, but it only shows the extent for the first time it's opened.  It doesn't update as the user moves around the map.  How do I get it to update?
<?xml version="1.0" encoding="utf-8"?>
// Display the extent URL for the user
<BaseWidget xmlns    ="com.esri.solutions.flexviewer.*"
      xmlns:mx   ="http://www.adobe.com/2006/mxml"
      x     ="600"
      y     ="220"
      widgetConfigLoaded ="init()">
 <mx:Script>
  <![CDATA[
   import mx.controls.Alert;
   import com.esri.ags.Map;
   private function init():void
    txtVersion.text = "https://server.com/flex/index.html?EXT=" + String(map.extent.xmin) + "," + String(map.extent.ymin) + "," + String(map.extent.xmax) + "," + String(map.extent.ymax);
 </mx:Script>
 <WidgetTemplate>
  <mx:Canvas id="viewStack" width="100%" height="100%" horizontalScrollPolicy="off">
   <mx:VBox width="100%" paddingTop="15">
    <mx:Text id="txtTitle" styleName="AboutTitle" text="URL for copying" width="100%" />
    <mx:Text id="txtSubtitle" styleName="AboutSubtitle" text="You can highlight and right-click (or CTRL-C) to copy the URL:" width="100%" />
    <mx:Text id="txtVersion" styleName="AboutVersion" text="" width="100%" />
   </mx:VBox>
  </mx:Canvas>
 </WidgetTemplate>
</BaseWidget>
CedricDespierre_Corporon1
Hello 🙂
Use this event:
map.addEventListener(ExtentEvent.EXTENT_CHANGE, repositionInfo); > this will call the repositionInfo function each time you move/zoom on the map.
Your code will look something like that:
private function repositionInfo(event:Event):void {
good luck!
Daniel,
   Cedric's code for adding an event listener for the extent change is exactly what you need. The only thing I would do is also remove the event listener when it is not needed as shown below, no need to continue to listen for the extent when the widget is closed or minimized (you have to always consider code performance/optimization). Also there is no real need for a config xml for this simple widget so eliminate the widgetConfigLoaded and use creationComplete.
      x     ="600"
      y     ="220"
      creationComplete ="init()">
 <mx:Script>
  <![CDATA[
   import com.esri.ags.events.ExtentEvent;
   private function widgetOpenedHandler(event:Event):void
    map.removeEventListener(ExtentEvent.EXTENT_CHANGE, repositionInfo);
   private function widgetClosedHandler(event:Event):void
 </mx:Script>
 <WidgetTemplate widgetOpened="widgetOpenedHandler(event)" widgetClosed="widgetClosedHandler(event)"
  widgetMinimized="widgetClosedHandler(event)">
   </mx:VBox>
  </mx:Canvas>
 </WidgetTemplate>
</BaseWidget>
