Timeslider - Set initial extent to end of slider
959
10-25-2011 11:23 PM
DanielBaternik
It would be great if there was a property to configure the time slider to set the initial time extent to the end of the slider scale. This is required when a user wishes to see the current view of information, but may wish to see historical data at some point.
Also, is there a simple way to do this with the current api?
JonettaNg
Hi depending on whether you have one thumb or two on your time slider.  This can be obtained by the following:
Assuming timeSlider is the ID of your Time Slider.
timeSlider.thumbCount
And the last thumb can be set using:
timeSlider.thumbIndexes[timeSlider.thumbCount - 1] = timeSlider.timeStops.length - 1;
I hope this helps.
RobertScheitlin__GISP
I could not get the above to work in the 2.5 API, but this works:
timeSlider.slider.setThumbValueAt(timeSlider.thumbCount - 1, timeSlider.timeStops.length - 1);
DanielBaternik
Thanks Rob,
I've had to park my work on this temporarily. Originally I tried the first suggestion but that didn't work for me either. I'll give you're option a try. I'm actually embedding the time slider component into your TOC component. If you're interested i can post the amendment.
cheers
Daniel,
   Sure I would be interested to see what you did.
