Symbology from FeatureLayer
2246
9
09-29-2011 03:48 AM
BrunoPereira1
I got this problem, I have a FeatureLayer from Url
var featureLayer:FeatureLayer = new FeatureLayer(url);
But, the property Renderer (about symbology) in the FeatureLayer is null, and I want to change the the symbology properties.
I got a Polygon with the property Style "solid" and I want to change and set to "backwarddiagonal".
Thanks.
Bruno
RobertScheitlin__GISP
Bruno,
   Simply define one in code and assign it to the feature layer.
                            var sr:SimpleRenderer = new SimpleRenderer();
                            var oLine:SimpleLineSymbol = new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID,0xff0000,0.8,1);
                            sr.symbol = new SimpleFillSymbol(SimpleFillSymbol.STYLE_BACKWARD_DIAGONAL,0xff000,0.8,oLine);
                            featureLayer.renderer = sr;
BrunoPereira1
Hi.. in a url property about symbology i have this
Renderer:
Simple Renderer:
Symbol:
Simple Fill Symbol:
Style: esriSFSSolid, Color: [85, 255, 0, 255]
Outline:
Simple Line Symbol:
Style: esriSLSSolid, Color: [Undefined], Width: 0,4
BrunoPereira1
But how I get color properties?
Thanks!
BrunoPereira1
I can set a new renderer, but I have to keep the original color
Thanks
Bruno
BrunoPereira1
Thanks
Bruno
Bruno,
Bruno,
   Since the renderer is null I guess you would have to get the first feature from the feature layer and then get the symbol from the graphic and get all the way down to the simpleFillSymbol's color property. I don't have any code examples for this.
BrunoPereira1
Robert,
I've tryed that, but the symbol is null, like the FeatureLayer...
When I add that FeatureLayer on myMap the color and everything is the same way on the Mapserver, I just need to add with a different style.
I look Inside the FeatureLayer I can see on debug mode the property FeatureLayer > Extent > DefaultSymbol and there I have the style, but I don't have access, I can't set that property!
I can't get properties of the symbol from the FeatureLayer!
Thanks!
Bruno Faria
Bruno,
Bruno,
   You can get the renderer from the drawingInfo. Make sure that the layer is loaded first though by calling this line after the featureLayer.load event
featLay.layerDetails.drawingInfo.renderer
BrunoPereira1
Robert, Thanks for Help!
Bruno,
