Sticky move tolerance
3714
11-20-2013 04:45 AM
NajyaBatool
Does anyone know how to set or adjust the sticky tolerance within Flex 3.0?  It's very easy to pick up polygons and accidentally move them while digitizing, especially on a site with multiple users.
Najya
YueWu1
by Esri Regular Contributor
Hi Najya,
I know you mentioned the tolerance in digitizing. Here I found a sample code - identify features on esri Flex API might related to your question.
https://developers.arcgis.com/en/flex/sample-code/identify-features.htm
The tolerance is the number of pixels a feature is allowed to lie away from the clicked point in order to be counted as a result.
com.esri.ags.tasks.IdentifyTask, property: tolerance
https://developers.arcgis.com/en/flex/api-reference/com/esri/ags/tasks/supportClasses/IdentifyParame...
NajyaBatool
Hi Nathan,
Thanks for your reply.  However, I'm not so concerned with the Identify features tool.  My issue is with the Edit widget.  Sorry, instead of using the world "digitize" I should have said while in edit mode.  When the Edit widget is active and feature access to that service is enabled, one can digitize on screen.  In edit mode it is quite easy to accidentally pick up features and move them.  In Desktop ArcGIS there's a sticky tolerance setting which prevents this.  I wondered if there's anything similar to this in the Flex API.
Najya
NajyaBatool
Hi ESRI Flex team,
Any help is appreciated.
Najya
