hidden buttons and title of graphic.infoWindowRenderer
885
11-26-2013 12:44 AM
louislu
hi,
   I used the following way calling graphic's infoWindow:
   var infoWindowRenderer:ClassFactory;
   infoWindowRenderer = new ClassFactory(PopUpRenderer);
   infoWindowRenderer.properties = { popUpInfo: configurePopUpInfo(resultAttributes)};
   graphic.infoWindowRenderer = infoWindowRenderer;
   and How do I can hide the button and title,to achieve the same effect with the following
   map.infoWindow.labelVisible = false;
   map.infoWindow.closeButtonVisible = false;
   map.infoWindow.show(point);
   thanks
   charlse
   I'm using esri 3.5 api
DasaPaddock
louislu
Thank you for your reply, It is a good solution to my problem�??
    thanks again!
    charlse
