Simple question: Adding a MapService in the API
1230
01-31-2012 04:22 AM
HannesRömer
Hello!
Sorry for my beginner question: After I successfully could open and compile the samples via Flash Builder, I would like to add an own map service that I created with ArcGIS Server for a web application. When compiling my application I don't see anything. What went wrong?
In Flash Builder I wrote:
<<?xml version="1.0" encoding="utf-8"?>
<s:Application xmlns:fx="http://ns.adobe.com/mxml/2009"
      xmlns:s="library://ns.adobe.com/flex/spark"
      xmlns:esri="http://www.esri.com/2008/ags"
      pageTitle="Using ArcGISImageServiceLayer">
<esri:Map>
  <esri:ArcGISTiledMapServiceLayer url="http://columbus/ArcGIS/rest/services/vabene_temp/GIS_Flex_Parkraeume1/MapServer"/>
</esri:Map>
</s:Application>
This URL works when copying it in my webbrowser. I attached the contents of the webpage (txt) which I got when typing the url in the browser.
Maybe I have to define layers, because the service include three layers?!
Thank you 😞
Hannes
RobertScheitlin__GISP
Hannes,
   Try using this instead of ArcGISTiledMapServiceLayer:
<esri:ArcGISDynamicMapServiceLayer url="http://columbus/ArcGIS/rest/services/vabene_temp/GIS_Flex_Parkraeume1/MapServer">
Don't forget to click the top arrow (promote) and to click the Mark as answer check as shown below:
HannesRömer
Robert,
a simple answer to a simple question. Thank you very much. It works 🙂
Hannes,
   So the reason that the first code you had didi not work is the fact that your map service is not cached. Only cached map services use the ArcGISTiledMapServiceLayer.
