Simple Map Point Question
4262
16
10-21-2012 07:51 AM
PhilipTownsend
I am new to the Flex API but not new to GIS programming.
I have a message service that will be reporting locations via Lat/Lon and I will need to locate a simple graphic on the map specified by the incoming location coordinates. It seems like this should be really simple. I have created a simple click event for testing. The points show up at the correct locations, but how do I get them to be represented by lat/lon coordinates? Obviously, the end goal is not to be using mouse clicks to determine locations. Thanks!
         <esri:SpatialReference id="wgs" wkid="4326"/>
   private function onMapClick(event:MapMouseEvent):void{
    var g:Graphic = new Graphic();
    //g.geometry = new MapPoint(38.0594, 81.1121, wgs); //event.mapPoint;
    g.geometry = event.mapPoint;
    grLayer.add(g);
    Alert.show("Mouse clicked at: " + event.mapPoint.x + "|" + event.mapPoint.y);
KenBuja
MVP Esteemed Contributor
He just needed to project the point into Web Mercator, as asked in another thread.
AnthonyGiles
Honored Contributor
Philip,
Assign the lat/long coords to two separate variables or to an array then use these variables when creating your mappoint, ie if you have a string called coordstring set to "38.0594,81.1121"
var coords:Array = coordstring.split(",");
var g:Graphic = new Graphic(new MapPoint(new MapPoint(coords[0],coords[1],wgs)));
grLayer.add(g);
Regards
Anthony
IvanBespalov
Philip,
Sample 1 (with sources) - Project a point using GeometryService
Sample 2 (with sources) - Project a point using WebMercatorUtil
Good luck.
PhilipTownsend
Thanks for the reply Anthony!
Unfortunately something else is wrong. When I pass in the coordinates directly to the graphic variable,
the graphic appears but is placed at 0,0 rather than at the specified coordinates. Any idea why this is happening?
Thanks!
AnthonyGiles
Honored Contributor
Philip,
What happens if you add the graphic this way:
var g:Graphic = new Graphic(new MapPoint(new MapPoint(38.0594, 81.1121,wgs)));
Regards
Anthony
KenBuja
TomRauch
Hi, I am a bit stumped - I would like to use the myMap.zoom(1 / 16, myGraphicMarker) I saw Robert S. post in another thread.
But...
var myGraphicMarker:Graphic = new Graphic(new WebMercatorMapPoint(longitude, latitude),
      new SimpleMarkerSymbol(SimpleMarkerSymbol.STYLE_DIAMOND, 22, 0x009933));
     myGraphicsLayer.add(myGraphicMarker);
     myGraphicsLayer.refresh();
          myMap.zoom(1 / 16, myGraphicMarker);
when I run that, Flex tells me I have an error 1067: Implicit coercison of :Graphic to unrelated type: MapPoint (truncated error message).  I understand what a coercion problem is, but I am curious why MyGraphicMarker is not recognized as a MapPoint.  Is it because I am declaring a WebMercatorMapPoint?
Thanks, Tom
RobertScheitlin__GISP
Tom,
   It is because myGraphicMarker is a graphic and not a MapPoint or a class that extends geometry.
Try
myMap.zoom(1 / 16, myGraphicMarker.geometry as MapPoint);
TomRauch
Thank you Robert, I suspected that was the case...
However, when I run your code above, I now receive:
TypeError: Error #1009: Cannot access a property or method of a null object reference.
I moved the 'refresh' property below the zoom, thinking that might make a difference but, I still get the error.
          myMap.zoom(1/16, myGraphicMarker.geometry as MapPoint);
Thanks again, Tom
Tom,
  Can you put a breakpoint in your code on this line an test to see what is null? Maybe you need to use:
myMap.zoom(1/16, myGraphicMarker.geometry as WebMercatorMapPoint);
