Writing more than just an address field from a Locator in Flex
2577
12-17-2012 05:24 AM
KarlBarker-Ottley
I have a locator service which has access to a variety of fields and would like to write one of these fields into a tooltip that appears if the address is successfully located. The field is called ???Street_ID???. I am trying to adapt the example script found in the ESRI Flex Samples site - below is an extract of the mxml; if someone could highlight what I need to include to get this field to write, It would be appreciated:
<fx:Script>
<![CDATA[
import com.esri.ags.Graphic;
import com.esri.ags.geometry.MapPoint;
import com.esri.ags.layers.GraphicsLayer;
import com.esri.ags.tasks.supportClasses.AddressCandidate;
import com.esri.ags.tasks.supportClasses.AddressToLocationsParameters;
import mx.controls.Alert;
import mx.rpc.AsyncResponder;
private function doFind():void
var parameters:AddressToLocationsParameters = new AddressToLocationsParameters();
parameters.address = { SingleLine: onelineaddress.text };
parameters.outFields = ["Loc_name"];
locator.addressToLocations(parameters, new AsyncResponder(onResult, onFault));
function onResult(candidates:Array, token:Object = null):void
if (candidates.length > 0)
var addressCandidate:AddressCandidate = candidates[0];
var myGraphic:Graphic = new Graphic();
myGraphic.geometry = addressCandidate.location;
myGraphic.symbol = mySymbol;
myGraphic.toolTip = addressCandidate.address.toString();
myGraphic.id = "graphic";
myGraphicsLayer.add(myGraphic);
myMap.centerAt(myGraphic.geometry as MapPoint);
if (addressCandidate.attributes.Loc_name.search("RoofTop") > 0)
myMap.scale = 9027.977411;
myInfo.htmlText = "<b>Found:</b><br/>" + addressCandidate.address.toString();
else
myInfo.htmlText = "<b><font color='#FF0000'>No Location Found</b></font>";
Alert.show("Sorry, couldn't find a location for this address"
+ "\nAddress: " + onelineaddress.text);
function onFault(info:Object, token:Object = null):void
myInfo.htmlText = "<b>Failure</b>" + info.toString();
Alert.show("Failure: \n" + info.toString());
private function clearMap():void
myGraphicsLayer.clear();
Alert.show("Points cleared");
</fx:Script>
Karl
KarlBarker-Ottley
I was wondering if anyone has had any further thoughts on this issue?
Karl
