show/hide hyperlinks
3152
9
07-16-2012 02:18 PM
DavidBrooks3
I'm wanting to show a popup hyperlink if there is feature data or hide it if the value is empty string or null.  I've searched the forum but was unable to locate a solution.
Thank you,
AustinDavis
You can put the link in an html anchor tag (<a>) and add it to the htmltext attribute of a text tag (<mx:Text>).
Put the text tag as a child in the infoWindow (map.infoWindow). Then call the show/hide methods on the infoWindow when the user interacts with a feature.
DavidBrooks3
Here is a snip from my popup xml where I am trying to show/hide a link.  How is the {Location} parameter value used in JavaScript?
<configuration>
[LEFT][/LEFT] <title>{REVIEW_DESC}</title>
[LEFT][/LEFT] <script type="text/javascript">
[LEFT][/LEFT]  var Att = {Location: "Location"}
[LEFT][/LEFT]  function hideDiv() {
[LEFT][/LEFT]  if (Att = '')  {document.getElementById("testdiv").style.display = 'none';}
[LEFT][/LEFT]  }
[LEFT][/LEFT] </script>
[LEFT][/LEFT] <description>
[LEFT][/LEFT]  <![CDATA[
[LEFT][/LEFT]<div id="testdiv"><A href="http://000.000.000.000/flexviewers/app/{Location}" target=_blank>Location</A></div>
]]></description>
</configuration>
Your help is appreciated.
AustinDavis
Maybe something like this?
I think the Att variable is an object. You need to get the value of 'Location' out of the Att object.
So your script would be something like:
if (Att = '') {document.getElementById("testdiv").style.visibility= 'hidden';}
}else{
 document.getElementById("testdiv").style.visibility='visible';}
Where you have the "testdiv" already added to the DOM somewhere.
<div id="testdiv">
<a href="{'http://000.000.000.000/flexviewers/app/'+Att.Location.toString()}"  target=_blank>Location</a>
</div>
DavidBrooks3
Therein lies my issue.  I already have the {Location} value provided in the xml of the popup.  I'm attempting to verify in javascript if it is an empty string and if so to not show the div.  How do I use the {Location} value in javascript?
Thank you,
AustinDavis
David,
Sorry-- misunderstood.
So you would like to know if the location string (part of the URI) is empty?
If you have the div:
<div id="testdiv">
</div>
Then in javascript you'll use similar code as above, but add a check to the location:
You will use the equality operator '=='.
    if (Att.Location.toString() == ''){ //if the Att object's location is cast to a string and is empty
         document.getElementById("testdiv").style.visibility= 'hidden';} //hide the div
    }else{ //if it is not an empty string
 document.getElementById("testdiv").style.visibility='visible';}//show the div
Is this closer to what your asking?
DavidBrooks3
Thanks Austinstig but I'm still getting the link regardless if {Locations} is empty string or not.  Here is my popup xml.  Am I doing something wrong?
<?xml version="1.0" ?>
<configuration>
  var Att = {Locations: "Locations"}
  if (Att.Locations.toString() == ''){ //if the Att object's location is cast to a string and is empty
</script>
<description>
  <![CDATA[
<div id="testdiv">
<a href="{'http://000.000.000.0/flexviewers/Location/'+Att.eLocation.toString()}"  target=_blank>Location</a>
</div>
</configuration>
AustinDavis
Let's see:
I had in error in my earlier code (extra brackets).
         document.getElementById("testdiv").style.visibility= 'hidden'; //hide the div
 document.getElementById("testdiv").style.visibility='visible';//show the div
in your code:
"eLocation" is not a property of the Att object.
Are you able to debug your JavaScript by using something like firebug plugin in firefox?
DavidBrooks3
Good morning Autsin,
Unfortunately I do not have a Java debugger so I'm driving blind.  The crux of my issue is this.  The popup xml produces {Locations} data, so I have what I need in that respect.  I am failing to use the {Locations} data in the javascript.  Please disregard the "eLocations" typo.  I rename "Location" to "eLocation" in the appropriate places since that is the name of the field in the database.
<configuration>
  }else{ //if it is not an empty string  //if it is not an empty string
  document.getElementById("testdiv").style.visibility='visible';};
 </script>
 <description>
  <![CDATA[
<div id="testdiv">
<a href="{'http://146.129.110.197/flexviewers/app/Locations/'+Att.Locations.toString()}"  target=_blank>Location</a>
</div>
Location: {Locations} // HAS DATA I want to use in the javascript
Location2: {Att.Locations.toString()}  // NO DATA coming from javascript
</configuration>
Thanks for your time and help,
AustinDavis
David,
Are you successfully getting your "Locations" data to load into an object?
I assume you have a feature Layer with the field [Location] containing a link for each feature.
When you select (e.g. RollOver, click, etc.) a feature you should get it (i.e. event.target ). This should be returned to you as a graphic although you may need to cast it to a graphic.
In the event.target graphic, get the attributes (event.target).attributes. Then get the position of the [Location] attribute with something like "attributes[0]" or attributes["Location"].
This should return the link.
Unfortunately I usually code in flex and only vaguely familiar with the javascript API (although esri tells me there web api's are all similar). So i have described a logic I would use. I apologize for not solving your issue!
