Selection Color in Feature layer selection mode
2606
04-25-2012 07:01 PM
Yusufalbanki
Hi everybody,
I am using feature layer selection mode in my application, but I have problem with removing the selection color, because I already handle the selected features using renderer , so I do not need the selection color
Is there way to remove it or change its alpha to be invisible
Thanks
DasaPaddock
There currently isn't an easy way to turn off the selection glow color, but a workaround is to listen for the selectionComplete event and then set the filters property on each selected graphic to an empty array.
IvanBespalov
This way we work with selection symbol:
private var selectionSMS:SimpleMarkerSymbol = new SimpleMarkerSymbol(SimpleMarkerSymbol.STYLE_CIRCLE, 30, 0x00FF00, 0.5);
// private var selectionSMS:SimpleMarkerSymbol = new SimpleMarkerSymbol(SimpleMarkerSymbol.STYLE_CIRCLE, 6, 0x000000, 0);
* Listen feature layer update end handler
protected function onFeatureLayerUpdated(event:LayerEvent):void
    if (featureLayer.selectedFeatures != null && featureLayer.selectedFeatures.length > 0)
        Graphic(featureLayer.selectedFeatures[0]).symbol = selectionSMS; // for points
Yusufalbanki
Thank you for your reply,
I checked your code, but still the result of the selection surrounded with the selection color. Do you have another solution?
Regards,
Yusuf
DasaPaddock
Yusufalbanki
Thank you very much, it works
