Scale Text instead of Scale Bar?
3147
10-31-2012 09:51 AM
ionarawilson1
Is it possible to have in a web app a dynamic scale text (like 1:24,000) instead of a scale bar? If so, where can I find an example or code snippet? Thanks
AnthonyGiles
Honored Contributor
Ionara,
You need to use a number formatter, add a declaration
<fx:Declarations>  <mx:NumberFormatter id="numFormatter" precision="0" useThousandsSeparator="true"/> </fx:Declarations>
Then you can use the formatter on your number
<mx:Label text="1:{numFormatter.format(myMap.scale.toFixed(0))}"/>
Regards
Anthony
ionarawilson1
Here is the answer
   <mx:Label text="Current map scale:" fontWeight="bold"/>
   <mx:Label text="1:{myMap.scale.toFixed(0)}"/>
Not sure how I can have the thousands separator on the scale so I will post another thread!
AnthonyGiles
Honored Contributor
Ionara,
Regards
Anthony
ionarawilson1
Thank you Anthony!
I created a formatter but instead of creating the label directly I created a function for the extentChange event of the map:
  private function updateScale():void
    scaleText.text = myNumberFormatter.format(myMap.scale).toString();
The scaleText is a label I created. I believe your version is better because it is much simpler!!! Thanks again!
RhettZufelt
MVP Notable Contributor
I have it with my coordinates as per this thread:
http://forums.arcgis.com/threads/24407-Show-scale-with-coordinates
R_
ionarawilson1
Great link for adjusting the scale format Rhett ! Thanks!
