Saving a session and Bookmarks
1155
08-25-2010 05:44 AM
FrankTrevino
Not sure if this is possible or not, but I thought I would ask the question.
I know the Bookmark widget saves the extent, but can it also or is there a way to also save what layers were clicked on, so when a user clicks on a saved Bookmark it, not only does it zoom to the extent, but will also turn on the layers there were saved when the Bookmark was added. I want to be able to save the session, so a user can just click on it (the Bookmark) without having to turn on and off certain layers again and again.
Thanks.
Frank
KevinThomas
Hi Frank,
I was wondering if you found a solution?  I'm trying to do the same thing.
thanks,
Kevin
MattiasEkström
I haven't done this, but I do save visible layers when user close the appliaction and load them when the user opens it again. The code I use for saving och loading visible layers might help you.
Saving visible layers to SharedObjects:
settingsSO = SharedObject.getLocal("HlsbgSettings");
    var map:Map = ViewerContainer.getInstance().mapManager.map
    acVisLayers = new ArrayCollection();
    MapUtil.forEachMapLayer(map, function(layer:Layer):void {
     var layVisAc:ArrayCollection;
     if (layer is ArcGISDynamicMapServiceLayer) {
      layVisAc = ArcGISDynamicMapServiceLayer(layer).visibleLayers;
     } else if (layer is ArcIMSMapServiceLayer) {
      layVisAc = ArcIMSMapServiceLayer(layer).visibleLayers;
     } else if (layer is ArcGISTiledMapServiceLayer) {
      layVisAc = ArcGISTiledMapServiceLayer(layer).visibleLayers;
     var lvisObj:Object = {
      visible: layer.visible,
      visarray: layVisAc
     acVisLayers.addItem(lvisObj);
    settingsSO.data[VISLAYERS] = acVisLayers;
settingsSO.flush();
visible layers from SharedObjects:
    if (settingsSO.size > 0) {
     var acVisLayers:ArrayCollection = settingsSO.data.vislayers as ArrayCollection;
     if (acVisLayers.length > 0){
       var cLayId:int = 0;
       for(var i:Number=0; i < acVisLayers.length -1;i++)
        if(acVisLayers.name == layer.name)
         cLayId = i;
         break;
        layer.visible = acVisLayers[cLayId].visible;
        ArcGISDynamicMapServiceLayer(layer).visibleLayers = acVisLayers[cLayId].visarray;
        ArcIMSMapServiceLayer(layer).visibleLayers = acVisLayers[cLayId].visarray;
(The code is actually from something Robert Scheitlin wrote for SFV 1.3 that I've modified just a little bit to work in my SFV 2.1)
