Sample Flex Viewer Not working
2380
12
07-19-2010 05:45 PM
Brahmananda_NehruKhandrika
Hi
I a not able to make  Sample Flex Viewer to wrok with my services.  I have already uploaded my config and crossdomain files.
RobertScheitlin__GISP
Sounds like the same old issue discussed many time. Look here.
http://forums.esri.com/Thread.asp?c=158&f=2421&t=297777&mc=8#929557
I am new to Flex Viewer. I have opened the MapManager.mxml in notepad and commented Line no 147. I have reopened the flex viewer and I can not see my services.
kbnehru,
   For changes to an mxml to take effect than you have to recompile the mxml into a swf file. You need something like Flash builder or older Flex Builder. If you do not have flash builder than changing any code is going to be tough.
Thanks for the help.
I have recompiled the app using Flash Builder and I am able to see my services. What steps are to be taken to copy the application to web server.
regards
Nehru
Brahmananda Nehru Khandrika,
   If you are using Flash or Flex Builder than just export a release build and copy all the files from the bin-release to a web server.
I am using Flash Builder 4 Premium. I am following Developer's Guide "Create GeoWeb Applications with Sample Flex Viewer" Release May 26, 2009.
I have an Issue with Widgets.
Creating a mxml component and naming it to MyFirstWidget.mxml is fine. I am not able to proceed further with Optimization for the Flex Viewer Appliction represented by Index.mxml as I do not see Flex Modules in the drop down list when I right click and select Properties on my MyFirstWidget.mxml. Are there any issues with Flash Builder 4. I am new to Flex environment, could someone help me with the way around for creating widgets.
regards
Nehru
Nehru,
   You are misunderstanding a portion here
What you need to right click is the whole flex project and not just the mxml in the Flex Navigator window.
I was able to change the logo.png but not powered by ESRI.PNG.
I have renamed the existing logo.png and powered by ESRI.png and copied my own png files as logo and powered by ESRI. I am able to see the change of Logo but not powered by ESRI.png.
regards
Nehru
Nehru,
      here is a thread about replacing the esri logo.
http://forums.arcgis.com/threads/8784-replace-powered-by-ESRI
