Repeater CurrentItem Value and Where Clause
2309
10-13-2010 03:56 PM
KomanDiabate
Hello All,
I am trying to figure it out how setup the where clause on my query by pulling the value from the wRepeater on the Flex Sample Viewer. However, I am unable to correclty read the value to the query where clause. I also tried to store the value to a simple mx:label and I am still having problems.
Can someone please help me figure this out, or tell me if this is even possible.
Thanks.
<esri:QueryTask id="existingQueryTask" showBusyCursor="true"
            url="http://ArcGIS/rest/services/Test/BaseLayers/MapServer/3" />
         <esri:Query id="exParkQuery" where="ParkId='{wRepeater.currentItem.ParkId}'" returnGeometry="true">
            <esri:outFields>*</esri:outFields>
        </esri:Query>
Drew
Here is a sample that shows how to get the item.
Take a look at the code "doQuery(event...)" and see how to get the repeater index then get that item from your array.
<?xml version="1.0" encoding="utf-8"?>
<s:Application name="Repeater Test"
      xmlns:fx="http://ns.adobe.com/mxml/2009"
      xmlns:s="library://ns.adobe.com/flex/spark"
      xmlns:mx="library://ns.adobe.com/flex/mx" xmlns:esri="http://www.esri.com/2008/ags">
 <fx:Script>
  <![CDATA[
   import com.esri.ags.events.QueryEvent;
   import mx.controls.Alert;
   import mx.states.State;
   private function doQuery(event:Event):void
    var state:String = arrList.getItemAt(event.currentTarget.repeaterIndex).toString();
    var where:String = "STATE_NAME = '"+state+"'";
    query.where = where;
    query.outFields = ["STATE_NAME"];
    queryTask.addEventListener(QueryEvent.EXECUTE_COMPLETE, onQueryComplete);
    queryTask.execute(query);
   private function onQueryComplete(result:QueryEvent):void
    //Alert.show("done");
 </fx:Script>
 <fx:Declarations>
  <s:ArrayList id="arrList" source="[New York,California,Florida]"/>
  <esri:QueryTask useAMF="false" id="queryTask" showBusyCursor="true" url="http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Demographics/ESRI_Census_USA/MapServer/5"/>
  <esri:Query id="query" outSpatialReference="{myMap.spatialReference}" returnGeometry="true"/>
 </fx:Declarations>
 <esri:Map id="myMap">
  <esri:extent>
   <esri:Extent xmin="-14298000" ymin="2748000" xmax="-6815000" ymax="7117000">
    <esri:SpatialReference wkid="102100"/>
   </esri:Extent>
  </esri:extent>
  <esri:ArcGISTiledMapServiceLayer url="http://server.arcgisonline.com/ArcGIS/rest/services/World_Physical_Map/MapServer"/>
  <esri:GraphicsLayer id="myGraphicsLayer" graphicProvider="{queryTask.executeLastResult.features}"/>
 </esri:Map>
 <s:VGroup horizontalCenter="0" verticalCenter="0">
  <mx:HBox>
   <mx:Repeater id="rpt" dataProvider="{arrList}">
    <s:Button click="doQuery(event)" left="20" top="335" label="{rpt.currentItem}" />
   </mx:Repeater>
  </mx:HBox>
 </s:VGroup>
</s:Application>
Drew
KomanDiabate
Drew,
Thank you so much for your reply. From your code, I understand you are storing the value in a string and then assigning it in the where clause. But I am having hard time applying this to the SFV.
In my application, I am already querying a set of data and displaying it in the widget. So I want to get the value (ID) of the data that I click on and store this in the label1.text (Please see attachment). Still not sure how to do this. Hope you can put me in the right direction.
Thanks.
Drew
Can you post your repeater code?
KomanDiabate
Sure, Here are the major parts.
1 -So the first query is just a regular SFV SearchWidget Query.
2- Second function tries to assign repeater id to label (unsuccessfully):
private function rep(event:MouseEvent):void
     t.text='{wRepeater.currentItem.ParkId}';
3- The third part is the query itself in actionscript where the where clause in located.
I noticed if I formulate the where clause like this everything will  work:
Where="ParkId=2" but I wont to get the id on the clicked repeater.
            url="http://*****/ArcGIS/rest/services/Test/BaseLayers/MapServer/3" />
        </esri:Query>
4 - Here is the repeater that call the first function on mouseup event.
<mx:Label id="t"/>
<mx:Repeater id="wRepeater">
<widgets:RecordData infoData="{wRepeater.currentItem}"      mouseOver="mouseOverRecord(event)" mouseOut="mouseOutRecord()" click="clickRecord(event)" mouseUp="rep(event)"/>
</mx:Repeater>
Thanks.
