remove items from map context menu
1548
11-26-2010 05:43 AM
grahamcooke
Hi
Can someone please tell me if it is possible to remove the two "about arcs" items from context menu, when u right click the map?
I have tried mapmenu.hidebuiltinitems but this doesn't work.
Hope someone can help!
Thanks
RobertScheitlin__GISP
Graham,
    All you have to do is look in the MapManager.mxml and find this line and comment it out
setViewerVersion();
grahamcooke
Robert,
Sorry for the belated reply. Thanks for this, it works....but only removes one of the options.
I two "about" options on right click: "about arcgis api for flex" and "about Arcgis viewr for flex". When I comment the line you suggested, it removes only the "about arcgis viewer for flex" option.
Hope you can help!
Graham,
   OK, i didn't notice that... Just do this then:
//setViewerVersion();
    map.contextMenu = null;
parvazparvaz
Hi, many thanks for your good solutions
I have a question:
How can I remove the "about arcs" items from "Overview" widget, when u right click it's map?
Regards
A.poker
