How to use Navigation Widget in an app using Flex API
1638
05-30-2012 12:02 AM
tanyabisen
Hello All,
I was trying to import Navigation widget in my project using Flex API.
How do I call the navigation bar in my application on load.
Please help me..Its urgent.
Tanya
KenBuja
MVP Esteemed Contributor
Great. Don't forget to mark the question as answered.
IvanBespalov
here is other discussion
To implement widget as it is (created specifically for ArcGIS Viewer for Flex) you must implement:
  • all interfaces and base classes used to create widget;
  • widget managers and containers;
  • widget configurations file (*.xml) parsers;
The result of this tedious work will be trimmed (without some functionality) ArcGIS Viewer for Flex, wasted time, corruption of your nervous system :rolleyes:
Creating own navigation tool is about 80 lines of code... you can skin it as you want ...
KenBuja
Take a look at this thread, which has a version of the Navigation widget that can be used in a non-Flex Viewer project.
tanyabisen
Thank you Ken.
I was just missing out on one line and your link did the trick.
Thanks a ton.
Regards,
Tanya
KenBuja
