QueryWidget InfoPopUp - resize
1409
09-24-2010 10:55 AM
philippschnetzer
I am using the QueryWidget to create a layer with traffic camera info - much like the out of the box example.  But I would like to make the InfoPopUp screen which portrays the image a little bigger and I cannot seem to find the place to make this change - I have made the actual container larger but the traffic camera image inside of it has stayed the same size....  Any help is much appreciated!
RobertScheitlin__GISP
Phillip,
Inside the InfoPopupWidget adjust the height of the image component as depicted below:
<mx:Image id="infoImage"
                  height="150"
                  buttonMode="true"
                  click="showLink()"
                  includeInLayout="false"
                  maxWidth="{infoCanvas.width - 10}"
                  useHandCursor="true"
                  visible="false"/>
philippschnetzer
Tried that and although it resizes the 'container' the traffic camera image is still the same small size.  I also tried making the width property larger but the actual image still remains the same size.
Thanks!
Phillip,
Ok they changed something on me.
You have to change the image height and this as well
<s:Group id="infoCanvas"
             width="210"
             minHeight="30">
philippschnetzer
Thanks, Robert!
