Query extent without returned geometries
921
07-29-2010 05:39 AM
Ganael_Jatteau
I need to get the extent of a layer with a where clause.
Right now, I use a QueryTask with returnGeometries=true, then I get the extent of all the graphics. Do you think there is a solution to do the same thing without downloading all the geometries to the client ?
Thanks!
EokNgo
Thanks!
Are you performing a necessary query to get a subset? If not...
You can get the extent of a layer itself using the GetDetails() method on the ArcGISDynamicLayer.
http://help.arcgis.com/en/webapi/flex/apiref/com/esri/ags/layers/ArcGISDynamicMapServiceLayer.html#g...
Ganael_Jatteau
Yes the problem is that I specify a where clause to get a subset of my layer.
Ideally, it would be nice to have the extent stored in the result when we query with "returnGeometry=false".
Ganael_Jatteau
A workaround is to set maxAllowableOffset with a high value. The returned geometries look like triangles but the query executes much faster. Then a GraphicUtil.getExtent() will do the job.
