Problems Using Query Builder Widget with Token secured services in FLEX app
1234
03-30-2011 09:04 AM
BarbaraPatterson
We have secured our map services with tokens and are able to view the data in our flex application. We also generated a token for the geometry service that is referenced by the Query Builder Widget. When I select the map service and click apply in the widget, the widget hangs. Does anyone know if there are any changes required to QueryBuilderWidget.mxml in order to work with the secured services? My QueryBuilderWidget.xml references the geometry server with the token.
Any help would be greatly appreciated!!!
Barb Patterson
