Print templates, any idea?
1748
5
11-12-2010 05:12 AM
Ganael_Jatteau
I'm looking for a solution to have templates in the print widget of the flexviewer.
For example, a user can pick-up a template before printing, and the template defines a size and a layout with all sort of surroundings (including map, legend, title, etc...).
I googled on this but didn't find a good solution to have an image or a pdf generated from a template. Maybe like fop in Java. Or something that reads a mxt from the server. I can start something from scratch but I post this message in case someone has a better idea !
EricGordon
Yes, I would like to know also!
galigeo did you get any resolution on this?
Thanks, Eric
also email me if necessary: [email protected]
RobertScheitlin__GISP
TorstenSchramm
Sounds good
JayHalligan
Has anyone accomplished this yet?  This would be so helpful.
TomSchuller
Hy,
maybe this one could help you:
http://www.arcgis.com/home/item.html?id=6809086326ea4c76bf026a32bb9dd698
Can define your own Layout on client side by coding or reuse the existting layout of the mapservice which runs the SOE.
Tom
