Problem with dynamic and tiled map services in the same application.
1629
06-30-2010 11:45 AM
SreeS
I have two map services in my application. One is dynamic and one is tiled.
1. <mapservice label="2009 Aerial" type="tiled" visible="false" alpha="1">http://www.vahgis.com/ArcGIS/rest/services/AERIALS/Images_2009/MapServer</mapservice>
2. <mapservice label="BaseDirect" type="dynamic" visible="true" alpha="1">http://www.vahgis.com/ArcGIS/rest/services/WEB/BaseDirect_0331/MapServer</mapservice>
I have 2 problems :
a. measurements using the DrawWidget and
b. GoogleStreetView.
I think it is to do with Projections and SpatialReference of the tiled layer.When I remove the tiled map service both the widgets seem to work fine.
Earlier I had problems with my Search and LiveLayer Widgets as well. But when I replaced all the "map.spatialReference" with "null" the widgets seemed to workfine.
The SpatialReference for my tiled map service looks like this in Rest:
Spatial Reference: PROJCS["NAD83 / Illinois East",GEOGCS["GCS_North_American_1983",DATUM["D_North_American_1983",SPHEROID["GRS_1980",6378137.0,298.257222101]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]],PROJECTION["Transverse_Mercator"],PARAMETER["false_easting",984250.0],PARAMETER["false_northing",0.0],PARAMETER["central_meridian",-88.33333333333333],PARAMETER["scale_factor",0.999975],PARAMETER["latitude_of_origin",36.66666666666666],UNIT["Foot_US",0.3048006096012192]]
SpatialReference for my dynamic layer is 3435.
The map services are public, so you can take a look at them.
The application is here: www.vahgis.com/flexviewer1.3/index.html
(The tiled map service is visible at 2188 - 500 scale.)
SreeS
For the googleStreetView I get this error:
[FalutEvent fault=[RPC Fault faultString=""falutCode="400" faultDetail="'inSR' parameter is invalid"] messageId=null type-"falult" bubbles=false cancelable=true eventPhase=2]
SreeS
Problem solved!!
The problem was with the Spatial-reference of the Aerial Map.
I just added a blank layer to the Aerial Map and the spatial-reference came back to the original. Now the draw and googleStreetView work normally!!
