Problem in Deploying
8504
15
06-10-2011 02:30 AM
MohammedIsmail
hi
i want to test my application by putting it on my webserver
i have exported it to release build its not working properly map is not getting displayed
what could be the reason
ISmail
RobertScheitlin__GISP
Ivan,
   Yes I did forget which forum I was posting to (happens when you answer so many questions in both forums).
I was not suggesting that Mohammed needed esri's support for fiddler or Fire Bug, just that he could use esri's tech support to help with his issue if he was not comfortable using a HTTP request web debugger like fiddler and fire bug... Some times experienced developers like us suggest things that seem overwhelming to beginners (Just what I have noticed over the years of supporting the Flex forums).
MohammedIsmail
hi
I have installed fiddler and it shows the process which am sending u in screen shot
thanks and regards
Ismail
MohammedIsmail
hi
it is working fine in debug mode as u can see the attach screen shot
Thanks & regards
Ismail
Mohammed,
   Are you using urls like "http://10.3.1.160:8099/ArcGIS/rest/services/xxxx/MapServer" or are you attempting to use "http://gisserver/arcgis/rest/services/xxxx/MapServer"? You can not mixed urls. If you are pulling up the app using the ip of the server than the url for all the layers in your app have to use the ip as well.
MohammedIsmail
<esri:Map id="MyML" width="85%" height="100%" x="10" y="10">
<esri:ArcGISDynamicMapServiceLayer id="myDynamicService" name="{myURL.selectedItem}"
load="myDynamicService.defaultVisibleLayers()"         url="http://gisserver/arcgis/rest/services/raichur/mapserver/" width="100%" height="100%">
</esri:ArcGISDynamicMapServiceLayer>
as u can the url above am using that internally and after putting it on IIS am accessing it with
http:\\localhost:8099\...
is there any way to over come this url problem as u told that both should be same
like we have the url maps.icrisat.org so iwant to access through this
waiting for reply
THANKS
Mohammed,
   So can you use this url and it returns the REST service page?
http://maps.icrisat.org/arcgis/rest/services/raichur/mapserver/
