Problem in Deploying
8505
15
06-10-2011 02:30 AM
MohammedIsmail
hi
i want to test my application by putting it on my webserver
i have exported it to release build its not working properly map is not getting displayed
what could be the reason
ISmail
MohammedIsmail
Hi
My application is working locally but
when tried by putting all the files into IIS root folder it is showing blank
> will it go directly to the location where the map services are present or we have redirect it ...
can anybody tell why its not working
Note:
"i have exported using opion Export -> Release build in adobe flash builder"
RobertScheitlin__GISP
Mohammed,
   Did you then copy the contents of the bin-release folder over to a virtual directory that is setup as an application (for IIS) or a new folder under httpdocs (for Apache)?
MohammedIsmail
yes i have copied all files that is generated by exporting the application
except the map service files
thanks
Mohammed,
   Is the ArcGIS Server and the Web server the same machine? If not then you need a crossdomain.xml
http://help.arcgis.com/en/webapi/flex/help/index.html#/Using_crossdomain_xml/017p0000001w000000/
MohammedIsmail
hi
Both (Flex application  & Arcgis Server )  are on same machine
Thanks & Regards
ISMAIL
MohammedIsmail
hi
As you told regarding cross domain xml  file i copied it but still am stuck am unable to view map when i browse , rest of the content i can view as you can see in attach screen shot
IvanBespalov
1 - What about Fiddler2 web debugger for "IE" or Firebug web debugger for "FF"? It gives you a look of all problems you have while sending requests to your ArcGIS server.
2 - What about tracing LayerEvent.load and LayerEvent.loadError events for your map layers?
Mohammed,
   To add to what Ivan suggests I would call esri tech support as the Flex Viewer is a support covered product.
IvanBespalov
1 - Robert, here is flex api forum (not flex viewer forum)
2 - You do not need any (Adobe, ESRI, Microsoft) support for it. (Microsoft has a link to fiddler in msdn)
3 - It's not decompiler 😄
5 - It just helps overview browser & application background work - and nothing more.
Good luck.
