Popups for polygon
1205
5
12-12-2011 09:17 PM
DessentArnaud
Hello
I have a problem, and I don???t understand where it comes from.
I created some popups for various layers in my application.
All of my layers are declared as dynamic to preserve the symbology.
When I try to use the popups on a point layer, it works.
But when I try this on a polygon layers, the popups don???t show up.
I don???t understand where is the problem. If I change the layer type to feature, the popups work.
I think this is not an error in the code. Moreover when I use the search widget, popups appear.
Do you think I???ve done a mistake somewhere or is the polygon type not compatible with de the declaration of dynamic type?
ManishkumarPatel
can you share your code snippet for better understanding.
Thanks!!
DessentArnaud
Of Course
The code of the file config.xml :
<operationallayers>
   <layer label="Espaces" type="dynamic" visible="false" url="myserver/arcgis/rest/services/Espaces/MapServer">
    <sublayer id="1" popupconfig="popups/PopUp_ZA.xml"/>
    <sublayer id="2" popupconfig="popups/PopUp_OCS.xml"/>
   </layer>
        </operationallayers>
And the code of the popups file
<?xml version="1.0" ?>
<configuration>
    <title>{nom}</title>
    <fields>
  <field name="nom"alias="Nom"/>
        <field name="type" alias="Type de Zone" visible="true"/>
  <field name="commune"alias="Commune" visible="true"/>
  <field name="contact"alias="Contact" visible="true"/>
  <field name="telephone"alias="Telephone" visible="true"/>
</fields>
</configuration>
IvanBespalov
a.dessent,
seems like xml attribute construct error:
<configuration>
<fields>
</fields>
</configuration>
try to put whitespace between attributes in XML:
<configuration>
<fields>
<field name="nom" alias="Nom"/>
<field name="commune" alias="Commune" visible="true"/>
<field name="contact" alias="Contact" visible="true"/>
<field name="telephone" alias="Telephone" visible="true"/>
</fields>
</configuration>
You can validate it here: http://validator.w3.org/#validate_by_input - just copy your xml and validate.
DessentArnaud
But my error don't come from this xml construct error.
That doesn't still work
RhettZufelt
MVP Notable Contributor
Is that xml for the point or polygon layer?  are your field names the same in both?
R_
