Popup issues : fields ignored while using <description>
833
10-27-2011 08:39 AM
JeffPerkins
If I'm using <description>, <fields> are ignored .  I've added the PopUpRendererSkin.mxml to my skins.  This resolved the blank after the second click..which is great.    Can anyone shed some light on this.  Maybe my configuration of description?
Here's my config.
<?xml version="1.0" ?>
<configuration>
    <title>{TxSedID}</title>
  <fields>
        <field name="TxSedID" visible="true"/>
        <field name="SampleType" visible="true"/>
        <field name="SampleDate" visible="true"/>
        <field name="SampleMethod" visible="true"/>
        <field name="Source" visible="true"/>
        <field name="County" visible="true"/>
        <field name="WaterBody" visible="true"/>
        <field name="ProjectExtent" visible="true"/>
        <field name="SampleDepth" visible="true"/>
        <field name="SampleDepthUnits " visible="true"/>
        <field name="CoreLength" visible="true"/>
        <field name="CoreLengthUnits" visible="true"/>
    </fields>
    <description>
    <![CDATA[<a> href='http://txsed.glo.texas.gov/txsed/dsweb/ApplySimpleSearch?value1={TxSedID}&D1=Collection-34'> Doc </a>]]>
</description>
<showattachments>false</showattachments>
</configuration>
RobertScheitlin__GISP
Jeff,
   It is not an issue what you are seeing is by design. It is either or not both.
