polygon barrier input location maximum / solve route question
801
02-02-2012 08:29 AM
JeffRhine
Can anyone explain what causes this error message to be returned: "The number of input locations loaded into PolygonBarriers exceeded the maximum of 200 allowed by the service."
I am able to use polygon barriers in many cases.  However, sometimes I receive the message above.  I can "force" the above message to be returned even with one polygon barrier with 5 points, if I draw this polygon "large" enough.
I'm using http://premiumtasks.arcgisonline.com/server/rest/services/NetworkAnalysis/ESRI_Route_NA/NAServer/Rou..., Flex 4.1.0 sdk, and agslib-2.4-2011-07-25.swc.
Thank You.
