Performing Synchronous queries in Flex
917
04-16-2014 12:17 PM
AndrewBlakey
Hi all:
I've become so used to asynchronous queries that when I came across a case where I need it to behave synchronously, I don't know what to do!
My attempted code is below. The problem is that the code gets to the return function before the embedded onResult function fires.  What I want is to query and determine the highest value in a field, then return that value +1.  I know I could do this as separate functions, but that becomes really ugly for the rest of my application.  I want a single function that is called, waits for an answer, then returns the answer.
   private function getNewProjectQuoteId():int
    var query:Query = new Query();
    query.where = "projectquoteid > 0";
    query.outFields = ["projectquoteid"];
    queryProjectQuotesTask.execute(query, new AsyncResponder(onResult, onFault));
    var previousInt:int = -1;
    function onResult(fSet:FeatureSet, token:Object = null):void
     for (var x:int = 0; x < fSet.attributes.length; x++)
      if (fSet.attributes.projectquoteid > previousInt)
       previousInt = fSet.attributes.projectquoteid;
    function onFault(info:Object, token:Object = null):void
     Alert.show(info.toString());
    return previousInt + 1
