Passing Parameters to flex viewer using flashvars from HTML
963
01-24-2011 09:18 AM
SantoshDonka
All,
I am trying to Passing Parameters to flex viewer using flashvars from HTML.
I am using FlashVars in html page found in HTML Template Folder and i was trying to access the parameter from SearchWidget.mxml init method using : FlexGlobals.topLevelApplication.parameters.
But i am getting Nulls all the time. Is there any thing am i missing ?
Thanks for your help in advance.
RavinHasseea
I am trying something similar as below i.e. would like to pass the location of the config.xml as a parameter from index.html
I need to do this as our proxy server is unable to rewrite the location of the file.
When trying to read the parameter from ViewerContainer.mxml, I get null
var flashvarConfig:String = FlexGlobals.topLevelApplication.parameters.config;
if (flashvarConfig)
       configFile = flashvarConfig;
Any suggestions?
All,
