Pass Search Parameters via URL
7543
30
06-23-2010 08:40 AM
SandraPanicucci
I've been trying to work my way through the http://forums.esri.com/Thread.asp?c=158&f=2421&t=294907&mc=104 thread but am still getting the following error.  I've been through this thread numerous times and don't seem to be able to see my problem. I'm fairly new at Flex and would greatly appreciate any help or suggestions.
TypeError: Error #1009: Cannot access a property or method of a null object reference.
at com.esri.solutions.flexviewer.widgets::SearchWidget/querybmpid()
at com.esri.solutions.flexviewer:MapManager/private:mapLoadComplete/com.esri.solutions.flexviewer:timerComplete()
at flash.events::EventDispatcher/dispatchEventFunction()
at flash.events::EventDispatcher/dispatchEvent()
at flash.utils::Timer/tick()
NatashaManzuiga
Thank u Robert, I will try with it...
Naty
I tried but I still got errors. What did I miss now? 😞
Naty
RobertScheitlin__GISP
Naty,
   So you are missing more code that was discussed in the original tread then.
//In BaseWidget.as add
        private static var _Widget:BaseWidget;
//Then in the initWidgetTemplate function add
   _Widget = this;
The QueryPID error means that you need to look in your SearchWidget for a public function called QueryPID. In the original thread I called it "public function queryPPIN(sParam:String):void".
The CustomDraw error means that your MapManager code is now looking for my EnhancedDraw widget instead of the standard draw tool of ESRI's. That code was not in Sandra's MapManger code so If you are not using my custom draw widget than I would say look back up at the beginning of this thread and grab Sandra's MapManager code she posted.
NatashaManzuiga
Naty,
   _Widget = this;
Thank u so much Robert, I m newbie with flex..
now I just cant find the original thread I called it "public function queryPPIN(sParam:String):void 😞
Robert
Naty,
   I am not sure what you have the function in your SearchWidget called...
Try adding this function to your SearchWidget.mxml if you don't have it.
//Add to your SearchWiget.mxml
   //query parameter
   public function querybmpid(sParam:String):void
    var i:Number = cboLayerText.selectedIndex;
    queryLayer = configSearchText.url;
    if(queryExpr){
    }else{
     queryExpr = configSearchText.expr;
    queryFields = configSearchText.fields;
    queryTitleField = configSearchText.titlefield;
    queryLinkField = configSearchText.linkfield;
    if (queryLayer)
     var queryTask:QueryTask = new QueryTask(queryLayer);
     var query:Query = new Query();
     var pExpr:String = sParam.toUpperCase();
     var expr:String = queryExpr.replace("[value]", pExpr);
     query.where = expr;
     query.outFields = queryFields.split(",");
     query.returnGeometry = true;
     query.outSpatialReference = map.spatialReference;
     queryTask.execute(query, new AsyncResponder(onResult, onFault));
     showMessage(loadingLabel, true);
     showStateResults(null);
             // on result
     function onResult(featureSet:FeatureSet, token:Object = null):void
      try
       var recAC:ArrayCollection = createRecordData(featureSet);
       addSharedData(widgetTitle, recAC);
       wRepeater.dataProvider = recAC;
       showMessage(selectionLabel + " " + featureSet.features.length, false);
       onLoadDone(null);
       map.cursorManager.removeAllCursors();
      catch (error:Error)
       showMessage(error.message, false);
       onLoadDone(null);
     //on fault
     function onFault(info:Object, token:Object = null) : void
      onLoadDone(null);
      showMessage(info.toString(), false);
If you call it querybmpid like above it should match the MapManger.mxml of Sandra's that I told you to switch to.
This is definitely not an easy piece of code to implement as there are many vital steps to the code that need to be in place and it helps if you try to understand the path that the code is taking.
Basically the application loads and check is there is a URL Parameter for the search and if there is once the map is loaded then programatically launch the SearchWidget and pass that parameter to it and run the query. So the MapManager needs to check for the paramter, find the search widget and launch it and then when you have the reference to the searchwidget call the (what ever function i.e. queryPPIN) and execute the search. So the MapManager has to call a valid function in the SearchWidget.
NatashaManzuiga
Naty,
   //query parameter
    if(queryExpr){
    }else{
    if (queryLayer)
     query.where = expr;
             // on result
      try
       onLoadDone(null);
      catch (error:Error)
       onLoadDone(null);
     //on fault
      onLoadDone(null);
Thank U so much Robert, I compiled and I built all my project....but nothing happen... 😞
I know it's really hard to understand why it doesnt work...but if u have time please help me ... in attachment I send u my MapManager, SiteContainer and SearchWidget.
Many thanks.
Naty
NatashaManzuiga
Many thanks.
Naty
Many Many Thanks....after a lot of concentration it perfectly works!!!! Thank u sooooooo much Robert!!
Naty
LeeAllen
Robert,
I hope this doesn't get old, but could you take a look at http://forums.arcgis.com/threads/4018-SFV-1.3-Pass-URL-to-Search-parcels and check out my issue if you get time?  I think I'm really close, just missing something.
Lee
SERESCO__S_A_SERESCO__S_A_
First at all, sorry for my English.
Robert I need help on your code...
I modified all the files:
BaseWidget.as
IBaseWidget.as
SiteContainer.mxml
MapManager.mxml
WidgetManagerDocked.mxml
But I allways obtain the same error... (null reference) in the MapManager.mxml
function timerComplete( event:TimerEvent ):void
         timer.removeEventListener(TimerEvent.TIMER_COMPLETE, timerComplete);
         var id:Number = SiteContainer.getInstance().getWidgetId("My Widget Label");
         var bWidget:IBaseWidget = SiteContainer.getInstance().widgetManager.getWidget(id) as IBaseWidget;
         if (bWidget){
          var bWidg:BaseWidget = bWidget.getInstance();
          var vSW:myWidget= bWidg as myWidget;
          vSW.myQueryFunction(id);
         } else {
          var bWidget2:IBaseWidget;
          bWidget2 = SiteContainer.getInstance().widgetManager.getWidget(id) as IBaseWidget;
          var vSW2:BuscarDerechoMinero = bWidget2 as BuscarDerechoMinero;
          vSW2.buscarDerecho(id_Derecho);
bWidget and bWidget2 are "null", and debugging into the code,...WidgetManagerDocked.mxml and function getWidget() the widgetTable and moduleTable vars are always lenght 0.
The widget ID is correct.
Can you help me?
Thanks in advance
Linoxmg,
Are you sure that
is the name of your search widget as it is defined in your config.xml?...
I put it as example.
My code was :
         var id:Number = SiteContainer.getInstance().getWidgetId("Búsqueda DM");
         if (bWidget){
          var vSW:BuscarDerechoMinero = bWidg as BuscarDerechoMinero;
          vSW.buscarDerecho(id_Derecho);
         } else {
and the config.xml
<widget label="Búsqueda DM" icon="com/esri/solutions/flexviewer/assets/images/icons/i_derecho.png" menu="menuWidgets" config="com/esri/solutions/flexviewer/xml/BuscarDerechoMinero.xml">com/esri/solutions/flexviewer/widgets/BuscarDerechoMinero.swf</widget>
this lines always returns null
and in this function, moduleTable and widgetTable always has 0 elements.
 public function getWidget(id:Number):IBaseWidget
       var widget:IBaseWidget;
       var label:String = configData.configWidgets[id].label;
       var icon:String = configData.configWidgets[id].icon;
       var config:String = configData.configWidgets[id].config;
       var url:String = configData.configWidgets[id].url;
       var preload:String = configData.configWidgets[id].preload;
       if (widgetTable.containsKey(id))
        widget = widgetTable.find(id) as IBaseWidget;
        widget.setState("maximized");
        var wObj:DisplayObject = widget as DisplayObject;
        scrollToWidget(wObj);
       else
        //module loaded
        if (moduleTable.containsKey(url))
         var modInfo:IModuleInfo = moduleTable.find(url) as IModuleInfo;
         widget = modInfo.factory.create() as IBaseWidget;
         widget.setId(id);
         widget.setTitle(label);
         widget.setIcon(icon);
         widget.setConfig(config);
         widget.setConfigData(configData);
         widget.setMap(map);
         var widgetDO:DisplayObject = widget as DisplayObject;
      widgetBox.addChild(widgetDO);
         widgetTable.add(id, widget);
        else
         return null;
         loadWidget(id, url,preload);
       return widget;
Help me!! jeje.
Thanks in advance
