Pass Search Parameters via URL
7535
30
06-23-2010 08:40 AM
SandraPanicucci
I've been trying to work my way through the http://forums.esri.com/Thread.asp?c=158&f=2421&t=294907&mc=104 thread but am still getting the following error.  I've been through this thread numerous times and don't seem to be able to see my problem. I'm fairly new at Flex and would greatly appreciate any help or suggestions.
TypeError: Error #1009: Cannot access a property or method of a null object reference.
at com.esri.solutions.flexviewer.widgets::SearchWidget/querybmpid()
at com.esri.solutions.flexviewer:MapManager/private:mapLoadComplete/com.esri.solutions.flexviewer:timerComplete()
at flash.events::EventDispatcher/dispatchEventFunction()
at flash.events::EventDispatcher/dispatchEvent()
at flash.utils::Timer/tick()
SandraPanicucci
This is the line from my config.XML ---  "BMP Locations" is the layer name in the map which contains the BMPID attribute.
<mapservice label="BMP" type="dynamic" visible="true" alpha="1" icon="com/esri/solutions/flexviewer/assets/images/icons/i_flag.png">http://arcgis.sd.gov/ArcGIS/rest/services/BMP2/MapServer</mapservice>>
I tried changing this to simply "BMP" which is what it sounded like you were saying it should be...the map service id/Label... got rid of the mapmanager.mxml error that popped up on the site but still leaves me with
***Error #1009: Cannot access a property or method of a null object reference***
on the SearchWidget
I guess that means I'm one step closer. I believe my problem now lies in this ---
public function querybmpid(sParam:String):void
    var i:Number = cboLayerText.selectedIndex;
    queryLayer = "http://arcgis.sd.gov/Arcgis/rest/services/BMP2/MapServer/0";
    queryExpr = "BMPID = '[value]'";
    queryFields = "BMPID";
    queryTitleField = "BMPID";
Section of the SearchWidget but many changes later I guess I still need help.
RobertScheitlin__GISP
Sandra,
   Try this
    queryFields = "*";
    queryLinkField = "";
SandraPanicucci
Thank You very very much! It worked.
NatashaManzuiga
Sandra, can u send me your sitecontainer...there is something that doesnt work on mine..Im trying to do the same thing u did...
Naty
SandraPanicucci
Natasha, I've attached my sitecontainer. Hope it helps, if not, hopefully Robert will respond. He's the best.
NatashaManzuiga
Oh....so fast!! :))))Thank u...
Naty
NatashaManzuiga
This is my code in mapmanager.mxml...in attachment the code and the error...
NatashaManzuiga
I see that I dont have this function getWidget(id) in widget manager  😞
SiteContainer.getInstance().widgetManager.getWidget(id)
Natasha,
   Yep you missed a couple of steps from the older thread.
//Add to the BaseWidget.as
   * Added by me
   * so that I could get the widget instance
  public function getInstance():BaseWidget
   return _Widget;
//Add to the IBaseWidget.as
   * Used to get a refference to this widget for code
  function getInstance():BaseWidget;
//Add to the WidgetManagerDocked.mxml
      public function getWidget(id:Number):IBaseWidget
       var widget:IBaseWidget;
       var label:String = configData.configWidgets[id].label;
       var icon:String = configData.configWidgets[id].icon;
       var config:String = configData.configWidgets[id].config;
       var url:String = configData.configWidgets[id].url;
       if (widgetTable.containsKey(id))
        widget = widgetTable.find(id) as IBaseWidget;
        widget.setState("maximized");
        var wObj:DisplayObject = widget as DisplayObject;
        scrollToWidget(wObj);
       else
        //module loaded
        if (moduleTable.containsKey(url))
         var modInfo:IModuleInfo = moduleTable.find(url) as IModuleInfo;
         widget = modInfo.factory.create() as IBaseWidget;
         widget.setId(id);
         widget.setTitle(label);
         widget.setIcon(icon);
         widget.setConfig(config);
         widget.setConfigData(configData);
         widget.setMap(map);
         var widgetDO:DisplayObject = widget as DisplayObject;
      widgetBox.addChild(widgetDO);
         widgetTable.add(id, widget);
        else
         return null;
         loadWidget(id, url);
       return widget;
NatashaManzuiga
Natasha,
   * Added by me
   return _Widget;
       else
        //module loaded
         widget.setId(id);
         widget.setMap(map);
        else
         return null;
       return widget;
Thank u Robert, I will try with it...
Naty
