Only one dynamic layer is visible in Flex Viewer
2587
08-09-2011 06:12 AM
CurtWalker
I'm probably missing something obvious, but I have added two operational layers to a Flex Viewer application as follows (generic names and locations inserted):
<layer label="Group 1" type="dynamic" visible="true" alpha="1"
                   info="widgets/InfoTemplates/SimpleInfoWinWidget.swf"
                   infoconfig="widgets/InfoTemplates/IWT_Fires.xml"
url="http://map.mydomain.com/ArcGIS/rest/services/folder1/service1/MapServer"/>
            <layer label="Group 2" type="dynamic" visible="true" alpha="1"
url="http://map.mydomain.com/ArcGIS/rest/services/folder2/service2/MapServer"/>
Only the first layer is visible when I view the application in a browser.  If I switch the order then the other one will be visible, just whichever is listed first in config.xml.
Is there a setting I'm missing that will make both of them visible?  It's as if one is masking the other but they are just points and lines.
IvanBespalov
Curt, read more about imageFormat property for dynamic type layers.
http://forums.arcgis.com/threads/27413-layer-transparency-not-working
