Map XY  data from Excel into Flex
8262
26
05-28-2012 08:58 PM
ShwetaMorkhandikar
I have the excel file with X Y location, i need to map these dynamically onto Flex API. I am using Flex API 2.5
tanyabisen
Hi Anthony,
I was going through this forum and I have a similar requirement however I dont see the source code attached. Can you please email me at [email protected].
Also, i have csv file link. I dont have the excel file stored at some location.. I converted the link from .csv to .xml but how do I parse it.
Can you please help me on that too.
Tanya
Shweta,
There is an example here but it will require you doing soming coding:
http://www.arcgis.com/home/item.html?id=173870a7926c4ef9b2a5121be0b46211
regards
Anthony
AnthonyGiles
Honored Contributor
Tanya,
Here is the link to my load data file, which will allow you to load local excel and csv files:
http://www.arcgis.com/home/item.html?id=cdac64f40b53435c9b191731fcd3c9c1
If you are running you web app on a network with Internet access you can also add a csv file directly within a layer tag, see:
http://resources.arcgis.com/en/help/flex-viewer/concepts/index.html#/CSV_GeoRSS_and_KML_layer_types/...
Regards
Anthony
MichaelVolz
Esteemed Contributor
Anthony:
Does this widget create a heat map for the data from Excel in the flexviewer web application?
AnthonyGiles
Honored Contributor
Michael,
Yes it has that option
Regards
Anthony
MichaelVolz
Has this widget been around for at least a few versions, as I thought I downloaded it for Flex 3.1 or 3.2?
AnthonyGiles
Honored Contributor
Michael,
It's an updated version of my add excel widget. You can now also add a csv file and the data will be reprojected to fit your basemap.
It has been released against version 3.4 of the api.
Regards
Anthony
JoeHewitt
I would like to use my own WKT (It does not have a WKID). Is this possible/ Will it require much alteration of the code?
