Flex Mobile and OAuth Question
925
09-30-2013 01:35 PM
MattSheehan
We are adding OAuth to a Flex Mobile app. We've looked at the online samples, but see none for Flex Mobile. We have the following:
   public function login():void
    //Oath authentication - App id
    var oAuthInfo:OAuthInfo = new OAuthInfo("........");
    IdentityManager.instance.registerOAuthInfos([ oAuthInfo ]);
    IdentityManager.instance.enabled = true;
    defaultQueryParameters = new PortalQueryParameters();
    portalService = new Portal();
    portalService.addEventListener(FaultEvent.FAULT, esriService_faultHandler);
    portalService.addEventListener(PortalEvent.LOAD, portalService_loadHandler);
    portalService.addEventListener(PortalEvent.QUERY_ITEMS_COMPLETE, portalService_queryItemsCompleteHandler);
    portalService.url = serverURL;
    portalService.signIn();
This works just fine, but we suspect we are missing some pieces for full OAuth. Could somebody let us know if we are correct, and what else we need add?
--Matt
DasaPaddock
To make it work with the defaults, you just need to make sure that your app registration allows the "urn:ietf:wg:oauth:2.0:oob" redirect URI. Additional functionality you may want to add to your app is to allow the user to sign out. See:
https://developers.arcgis.com/en/flex/api-reference/com/esri/ags/components/IdentityManager.html#sig...
