lose the "find an address" widget
735
07-30-2010 12:54 PM
JustinRiggs
this is another question I vaguely remember one of the presenters addressing at the UC (maybe I should have taken better notes?).
I'd really like it if I could open the site without a rogue widget already opened up. Is there any way to tuck that away until I actually want to use it? 🙂
Thanks!
DasaPaddock
You can remove the preload property in the config.
Reference:
http://help.arcgis.com/en/webapps/flexviewer/help/widgets.htm
DerekLaw
Esri Esteemed Contributor
Hi Justin,
In the config.xml file for your Viewer, under the <widgetcontainer> subsection, find the following XML code:
<widget label="Find an address"   x="70" y="94" preload="open" icon="assets/images/i_target.png"
                config="widgets/Locate/LocateWidget_US.xml"
                url="widgets/Locate/LocateWidget.swf"/>
And simply delete this part of the code:
preload="open"
This will make the "Find an address" widget not auto-load when the Viewer application loads.
Hope this helps,
JustinRiggs
baaah... feeling a bit sheepish over here. Thanks, folks.
