Legend for CartographicLineSymbol
1520
07-27-2010 01:15 AM
Ganael_Jatteau
I have a map with some CartographicLineSymbol on a graphic layer and I'm trying to build a legend.
I tried 2 solutions to draw a line symbol into an UIComponent but none of them works.
Solution 1:
var uic:UIComponent = symbol.createSwatch(20,15);
Solution 2:
var uic:UIComponent = new UIComponent();
uic.width = 20;
uic.height = 15;
var polyLine:Polyline = new Polyline();
var p1:MapPoint = new MapPoint(0,0);
var p2:MapPoint = new MapPoint(15,0);
var path:Array = new Array(p1,p2);
polyLine.addPath(path);
symbol.draw(uic, polyLine, null, this._map);
The line symbol has a width, a color. Any idea how to solve that problem?
Thanks!
RobertScheitlin__GISP
Ganael,
    Most cartographic lines use composite symbols and the documentation for the createswatch states
Creates a swatch for a symbol which can be used in a legend. Swatches only work with symbols which are supported in the FeatureService, i.e., swatches are not supported for CompositeSymbol, InfoSymbol and TextSymbol.
as far as it not working for the Symbol.draw method I don't know why that is not working.
SarthakDatt
Hey Ganeal,
This works for me:
<?xml version="1.0" encoding="utf-8"?>
<s:Application xmlns:fx="http://ns.adobe.com/mxml/2009"
    xmlns:s="library://ns.adobe.com/flex/spark"
    minWidth="955" minHeight="600"
    creationComplete="application1_creationCompleteHandler(event)">
    <fx:Script>
        <![CDATA[
            import com.esri.ags.symbols.CartographicLineSymbol;
            import mx.events.FlexEvent;
            protected function application1_creationCompleteHandler(event:FlexEvent):void
                var sym : CartographicLineSymbol = new CartographicLineSymbol("solid", 0xFF0000, 1, 5, CartographicLineSymbol.CAP_ROUND);
                vgrp.addElement(sym.createSwatch(50, 50));
    </fx:Script>
    <s:VGroup id="vgrp" paddingTop="100" paddingLeft="500">
        <s:Label text="Cartographic swatch test"/>
    </s:VGroup>
</s:Application>
Let me know if you still can't get it to work.
-- Sarthak Datt
ESRI Flex Team
