Layer On/Off
1098
02-08-2011 09:50 AM
MayJeff
I would like to use the same button to turn on/off a layer instead of showing 2 buttons.  I attached the code below.  Please help.  Thank you.
MitchKoyle
If you want to toggle the the visibility for two layers, you could try using a visible flag and have each layer use that flag to toggle their visible property. Please note that this will work fine for two layers, but if you need to toggle the visibility for more than two layers, you might need something similar to the 'Switching Basemaps'  sample.
I have modified your file and attached it to show you what I mean.
MayJeff
Thank you very much.  It works 🙂
