VB.Net - Add dataset name to combobox
755
02-08-2011 09:22 AM
ChrisOkeke
I'm using  the code below  to iterate and add dataset names in SDE GDB to a combobox. It works as expected however, I want to modify it to instead add only those that I specify by name. Another option is add those whose name strings start with, for example, tmpDB.gisadmin.state_.
Any help will be appreciated.
Dim pworkspacefact As IWorkspaceFactory
            pworkspacefact = New SdeWorkspaceFactoryClass
            Dim pworkspace As IWorkspace2
            pworkspace = pworkspacefact.Open(pOutSDEPropset, 0)
            Dim pDataset1 As IDataset
            pDataset1 = pworkspace
            Dim pEnumdataset As IEnumDataset
            pEnumdataset = pDataset1.Subsets
            pDataset = pEnumdataset.Next
            If TypeOf pDataset Is IFeatureDataset Then
                Do Until pDataset Is Nothing
                    cboDatasets.Items.Add(pDataset.Name)
                Loop
            End If
RobertScheitlin__GISP
Christian,
    Definitely the wrong forum!... Try:
http://forums.arcgis.com/forums/20-ArcObjects-All-Development-Languages
