Search 5 features closest to a point, & display results in a caculator type of form
785
02-08-2011 07:18 AM
xingwenchen
I'd like to create a widget within Flexviewer platform (Flex 3 or Flex 4) to do the following:
1. query a point feature from a business location layer or cursor location;
2. Search a client locations layer to find the closest 5 clients;
3. display results in the following way (like a table):
   Record #,          Name,            Distance(mi),             Unit Cost($),           Total Cost($)
       1     Client1            15
       2    Client2            15.6
       3    Client3            19.3
       4    Client4            21
       5    Client5            22.4
"Unit Cost" would be a user input box to specify a value, and the total cost would be calculated.
I appreciate your input & thoughts. If you can provide code samples, that would be awesome. Thanks.
Xingwen Chen
RobertScheitlin__GISP
Xingwen,
    First things first. Remember to post Flex Viewer questions to the Flex Viewer Forum:
http://forums.arcgis.com/forums/111-ArcGIS-Viewer-for-Flex
Where you would want to begin is with the Closest Facility Sample for determining the 5 closest clients.
http://help.arcgis.com/en/webapi/flex/samples/index.html?sample=ClosestFacility
xingwenchen
Thanks, Robert. That's good starting point. I'll give it a try.
Have a great day!
Xingwen Chen
