Keep info window on top of other widgets?
1089
11-09-2011 06:18 AM
RichardGwozdz
I am working on a web mapping widget using the ArcGIS flex API and ArcGIS Flex Viewer. I have a infoWindow popup when there is a mouse rollover on a map graphic. Problem: the infoWindow renders below other widgets which obscures the data in the info window. Is there a way to force the info window to render on top of all the other viewer widgets?
RobertScheitlin__GISP
Richard,
   No, Info windows are children of the map with is a element of the MapManager that is drawn under widget or the widgets would not be visible.
RichardGwozdz
Thanks Robert, that is good to know.
Richard,
